daza avatar image
daza asked
TSense install or not?
Hi Guys just got my Multiplus 2 48/5000 and started connecting it and noticed it comes with a TSense temperature sensor, has anyone used it and if you have more than one battery where you connecting it ie on the neg terminal for the battery isolation switch?
tsense installation
Alexandra avatar image
Alexandra answered ·
@Daza
The T sense is for temp compensation of the battery bank voltage if they are lead acid.
For lithiums it can be used for low temp cut off.
Should be connected to the negative of the battery bank directly. Since it is to sense the temp of the battery bank itself.
You can also use them on the Cerbo temp inouts and have fun there with it.
daza avatar image daza commented ·
Works a treat on the Cerbo GX thanks mate!
