k0s avatar image
k0s asked
Read out MPPT or Ve Smart Network State/Mode for Grafana
I wonder how to read out the VE.SmartNetwork state for the devices like the MPPT, Shunt and so on... for Grafana.
All i got is : No Data when querying:
SELECT last("value") FROM "solarcharger/NetworkMode" WHERE ("instanceNumber" = '289') AND $timeFilter GROUP BY time($__interval) fill(previous)
Doesnt matter if i use an explicit instance or based on the whole name. Or even when using the "solarcharger/NetworkState"
Thanks for your help :)
grafana
matt1309 avatar image
matt1309 answered ·
I'm not familiar with how you would go about this via Smart Network.
I imagine you've already looked into but I'll say just in case. An easy work around if you have one could be adding a raspi running venus os.
Atm they're painfully pricey but would make solution much easier getting the data via MQTT/modbus and forwarding to grafana or using GitHub - victronenergy/venus-docker-grafana
k0s avatar image k0s commented ·
Oh Thanks,
i am running Venus OS actually. but there are no entries or datapoints in VE.SmartNetwork.. even though "State" and "Mode" exist..
i just wonder if its generally not filled with data due to a bug or lack or whatever -.-
Thanks anyway
regards
matt1309 avatar image matt1309 k0s commented ·
What is the exact data you're looking for. I'll check my system see if I can see anything.
Do you have a preference of how you get the data in venus os? I can check MQTT, modbus or Node-red let me know which data you're after and if you've got a preference of which communication type in Venus os and I'll see if I've got anything.
