multivictor avatar image
multivictor asked
Issue with ESS setting on VRM/Multiplus 2
Since two days (after the "VRM Portal performance issues") the setting in my ESS is (without my intervention) changed from "Optimized without Batterylife" tot "Externel control". I cannot change this setting anymore in the control menu.
Edit: I can change the settings in the control menu but on the VRM portal screens it always show "Externel control". Before the problem (?) occured "Externel control" was not shown in the VRM portal but "Bulk", "Absorption",......
Is this a tempory problem and due to the VRM Portal performance issues or a individual problem of my installation?
Screenshot of the situation:
ESS
Paul B avatar image
Paul B answered ·
this will be because some fw has been updated on the cerbo I would think as you may have this set to auto update. also I would check that the inverters fw is on 502 if no then maybe update it.
Victron does not change settings, but a FW change may display things diferantly
external control means that the batteries BMS is looking after the charge profile as per the setting in the BMS
Well that would be my guess
nickdb avatar image
nickdb answered ·
The vrm event log should also register any changes made.
multivictor answered ·
Thx for the comments.
No auto update for the firmware/cerbo GX (is set to manual)
Nothing mentioned in the log.
Apparently the problem has already solved itself.
edit: to early happy :-).
This morning the same problem occured again.
sharpener avatar image sharpener commented ·
As I remember there has been a long-standing inconsistency in operating state as between the front panel and VRM when using ESS, I have just learned to ignore it as it does not seem to signify any deeper problem.
