karlheinz-weber avatar image
karlheinz-weber asked
Multiplus II Firmware FW 2926 502 change to 3 Phases after load ESS Master goes on low Battery
Hello, upgrade system from one MultiPlus-II 48/3000/35-32 230V to 3 with 3 Phases. Config no errors. After load Assistent ESS on Master show "low battery". Firmware is 2926 502. VE BUS reset to single. Same Problem after load Assistent ESS "low battery". Test on all 3 Multiplus same Problem single. best regards Karlheinz Weber
ESS
karlheinz-weber answered ·
Problem was wrong ESS settings, https://www.victronenergy.com/live/battery_compatibility:pylontech_phantom is the Solution.
