I was looking through my Lynx Shunt settings, then noticed my DC power draw had shot up, investigating why I found the shunt was clearing reading the wrong amperage.
So after trying several things, and shutting down as much as I could, I pressed the "Press to set to 0" to calibrate zero current, it appeared to do nothing, but it solved the problem, so I guess it calibrated to zero.
So I'm guessing that whilst I was looking through the Shunt settings on my phone, I inadvertently pressed the "Press to set to 0" button, surely there should be a confirmation dialogue?
Same goes for the synchronise state-of-charge to 100%, there was nothing when I pressed that, but it did it.
So as a suggestion, could you add a confirmation to those two please?
