Hello, I am installing a victron ESS where it is not possible to disconnect the mains live to go through the ET112, is there any other alternative 100A meter with contactless CT recommended and would be compatible with ESS and the CCGX. Thanks
If you are simply wanting to meter that phase, without requiring any of the additional features offered by a "smart meter" then the Victron listed CT will work well.
https://www.victronenergy.com/accessories/current-transformer-for-multiplus-ii
The above assumes you are using a product that allows an external CT connection, such as the MPII.
Here is a guide:
9 People are following this question.
