i have a running mosquitto deamon, who reads for example also data via bridge from openwb. So far so good. But i dosent get data from the victron ess.
My victron.conf file for mosquitto looks like that (tried also a lot of other topics and params with same result):
connection victron address 192.168.4.15:1883 topic # in 0 topic # out 0 start_type automatic try_private true
The connection is established, but nothing is published (i use mqtt-explorer to view data). So i try one step back and connect the mqtt-explorer directly to the ess with credential from above. I get a connection with Topic N/serial/keepalive and system, but nothing more.
I try to send then (raw)
R/[serial]/keepalive #or R/[serial]/system/0/Serial
but nothing happen and no more data will be shown as sayd above.
In the ESS is the mqqt explorer enabled and also the two way comunication (also tried without it). Always the same result from above.
Please help ;-)
Bfo
