Duncan McCallie avatar image
Duncan McCallie asked
Multiplus 24/3000/70 long transfer delay
Gentlemen,
It's getting COLD here in the PNW and when the 50amp 240AC shorepower breaker is occasionally (unintentionally) overloaded, there is a LONG delay before the Multiplus begins inverting. Am I to assume this is because there are excessive 120V loads or is something malfunctioning other than the operator?
I was under the impression the switch over was supposed to happen in nano seconds and this is new behavior.
Is there a simple way to diagnose this issue?
thanks in advance.
Your friend,
Sparky
transfer switch
Michelle Konzack avatar image
Michelle Konzack answered ·
It is one of your settings which cause the delay.
Can not remember how it is called, but it is the setting which make the MultiPlus more voltage tolerant.
If you have a stable shore voltage, disable this setting and it should go back to milliseconds.
