Tibor Kocsis avatar image
Tibor Kocsis asked
ESS - Feed in excess - EV Charger
I have several problems with the PV system.
1. Why is it not possible to set the battery charging current if feedin to the GRID are allowed?
2. How can charging be set up via the EV Victron charger when it is connected to the AC input but when charging starts, it consumes energy from the batteries? Why does it take it from the battery at all if the input is AC in? How to set it so that it does not drain the battery? I dont wanna set scheduled charging. It must be little automatic.
3. How is it possible to extract the summary of charging and consumed energy from the EV charger via the VRM portal? Is it that hard to program?
ESS
