Hi All,
Hopefully an easy question. When in ESS mode, please could someone confirm that rocker switch on the front of the Quattro will still disable the inverter function when in the 'charger only' position?
Colin
You are correct. If the power goes out, you will not have inverter function.
It can also be switched that way using the GX.
It will charge the battery using the internally configured parameters and pass through the power to loads.
48 People are following this question.
