jrohde avatar image
jrohde asked
lights turning off
When we turn on the LED lights the MPPT momentarily turns off the load, consequently no lights for about 3 seconds. The MPPT model is 75/15 (SCC010015050R). Solar input is 500 watts at nominal 24 volts. Lighting load is approx.60 watts maximum per switched circuit.
jbakuwel avatar image
jbakuwel answered ·
Hi there,
That sounds like a LVD (low voltage disconnect). Also check the paragraph (Battery Life in the data sheet) to see if that applies to your situation.
Jan
