laurenceh avatar image
laurenceh asked
QML help please adjust display of Pulse counter count setup page
Can someone help me with this qml, I now I need to work out how to hack qml but i'm stummped right now.
Setup Venus os 2.8 on Rpi 3B+
I have created a pulse counter service (to display my narrowboat engine hours) I am updating the 'trip' counter so that I can reset it using the console interface - it all works.
But the accumulated float rounding errors upset the display format see image here.
I know I need to change the qml in "PagePulseCounterSetup.qml"
Which currently says:
               MbOK {
                        description: qsTr("Reset counter")
                        value: itemCount.value
                        editable: true
                        onClicked: {
                                itemCount.setValue(0)
                        VBusItem {
                                bind: Utils.path(bindPrefix, "/Count")
But what do I need to change it to, to display 1 decimal place ?
I tried a few things but they did not work.
Thanks
qml
johanndo avatar image
johanndo answered ·
you can use 2 different ways, to set the decimals in the output
using a .format() statement or math.round() to format the value yourself
You can also use .toFixed(1)
Look in OverviewHub.qml how Victron formats the SOC and other output values.
like
value: itemCount.value.toFixed(1)
or when outputting a string:
text: itemCount.format(1)
You can also use the property
item.decimals : 1
or just when you bind an item:
decimals: 1
unit: "h"
etc.
laurenceh avatar image laurenceh commented ·
@JohannDo thanks toFixed(1) worked fine.
