Hi all,
When installing a grid meter on an ESS system is it necessary to install at the supply origin or is it intended to just meter PV generation?
The problem I have is the supply intake is in a different building.
Thanks in advance
Hi all,
Thanks in advance
Needs to be a point to supply to make the ESS system work correctly.
You can use RS485 wireless link to connect to it.
Regards
Rob D
NZ
Hi
As below link these are RS485 wire type they do have USB type which plugs into ther raspi3 etc.
https://www.aliexpress.com/item/32851253283.html?spm=a2g0o.order_list.0.0.7baf18029NUd2F
45 People are following this question.
