thom2 avatar image
thom2 asked
IP22 12/30 compatibility with 100/20 controller?
My IP 22 12/30 has been the only power source charging my 12v Battleborn house battery. It is powered from an inverter connected to start batteries/alternator -works great never any problems, Recently I added 2x 100 watt solar panels in series and wired a 100/20 controller into the Battleborn house battery and if I run solar controller and IP22 at the same time the IP 22 is over heating, it also made a clicking noise. The solar works fine no issues.
ip22
Overheating shouldn't happen.
Are the settings of the IP22 identical to the MPPT?
Is the IP 22 still working when the solar is off?
Wiring diagram would help a lot. Might be you've introduced a fault in the wiring,
Cristian avatar image
Cristian answered ·
Hola, puedes ver mi video con IP22+mppt smart 100 20 funcionando: https://youtu.be/Mq_cbDz95oA
