radiofan avatar image
radiofan asked
MPPT Solar controller setup issue
Ive replaced an old solar controller with a Victron Energy SmartSolar MPPT 100V 30 amp 12/24-Volt Solar Charge Controller. The previous setup also charged my cab battery as the solar output ran through the motorhomes control unit. Should this still be the case, as it doesnt seem to be charging after the leisure batteries are charged ?
Thanks
MPPT SmartSolar
kevgermany avatar image
kevgermany answered ·
It should be, as long as the settings and wiring are correct and the batteries are same type/voltage.
Please post screen shots of the solar parameter setup and the current/voltage readings. Battery details would help as well
radiofan answered ·
HI All the batteries are 12v lead acid sealed type and the solar output from the controller goes through the motorhomes control unit, as it did before. I will get a screen shot of how it is set up on the app
Thanks for your answer
Maybe check the connections/fuse to the cab battery as well.
