neil2910 avatar image
neil2910 asked
PV Current is higher than MPPT max input current
Please explain how the "Max Current @ MPP max. temp" is calculated which is causing this Warning in "VE-MPPT-Calc-4.0" calculation?
My PV Module rating as follows:
Pmax = 455W
Voc = 49.85V
Vmp = 41.82
Isc = 11.41A
Imp = 10.88A
I would have thought that the max overall current of MPPT would be Isc x 8 strings = 91.28A, but it's clearly not the case.
According to "VE-MPPT-Calc-4.0", I'm limited to only 6 Parallel strings and then giving a reading "Max Current @ MPP max. temp" of 92.3V
MPPT SmartSolar
klim8skeptic avatar image
klim8skeptic answered ·
Data sheet gives PV input as 70a.
