I've read many posts, the manual and even the Smart Solar Hex protocol and I can't figure it out.
In the bluetooth app I can configure the RX port function as follows.
The first one and the last 2 make sense and I get how they work (mostly)
What does "Load output Configuration" mean?
![](https://community.victronenergy.com/storage/attachments/19388-1619646920160.png)
Also If I pick "Load Output On/Off normal" how does that work with the load output settings below and with the Streetlight function? Is it some sort of AND/OR operation? The manual doesn't go into detail so I'm hoping someone from the community that knows how it works or perhaps someone from Victron might answer this
Thank you very much,
Alex
