Hola @Agustin ,
Este error , te dejo el link de todos los errores Ve bus. Si después de resetearlo no te funciona , contacta con tu distribuidor Victron para tramitar la garantía.
https://www.victronenergy.com/live/ve.bus:ve.bus_error_codes#error_26_-_internal_error
Should not occur. Switch all equipment off, and then on again; it will then resume operation. Contact Victron Energy if the problem persists.
Recovery: system remains off until restarted.
23 People are following this question.
