I’ve got 5 smart solar MPPTs hooked up with 5 VE direct to usb cords going to a usb hub which is then going to a USB port on Cerbo gx. I see the MPPTs on victron connect via Bluetooth but I can’t get them to show up on the touch screen. Any help.
If you connect one of those Solar chargers directly to the Cerbo GX (using the same VE.Direct-USB cable), is it seen by your Cerbo GX?
Move the Cerbo closer to the solar charge controllers for testing this.
That USB hub you are using is powered (meaning if it has a separate power supply)?
How long is the USB cable between the Cerbo GX and the USB hub?
How long are the VE.Direct-USB cables (including any USB extenders you might have) between the solar chargers and the USB hub?
The VE.Direct-USB cables are from Victron or DIY?
from experience some brands of USB hubs do not work, try some different brand hubs if you can -
more than likely the better the quality of the hub the more chance you will have that it works
but first test the one or two MPPTs work when directly connected to the cerbo as per above advise.
Also Try
plug ONE VE direct to usb cable into your 15ft usb cable then into the cerbo this should then test if the cable is ok
34 People are following this question.
