Can u use the Freedom Won eTower with the CCGX? Do you have to change the baud rate? Do you use the same settings as the Freedom Won Lite?
Your question is best addressed to the manufacturer but you can refer to this:
https://www.victronenergy.com/live/battery_compatibility:freedomwon
Victron & Freedom Won LiFePO4 Batteries - Freedom Won LiTE and eTower
24 People are following this question.
