What determines which "Load Output" setting on a MPPT 100/30 is selected? Specifically what does the "Battery Life" accomplish and does it require entering charging values?
From the manual:
BatteryLife algorithm:
This is a self adapting algorithm to maximize life of the battery. For more information see chapter BatteryLife.
I didn’t see a “BatteryLife Chapter” in the manual, though. My understanding is that it is an algorithm that monitors your system and adapts the settings within a range to those most likely to extend your battery service life. I’m not certain if it needs settings, or creates them based on your settings entered elsewhere. It will continue to adjust settings based on the algorithm during use.
From the manual:
Battery Life: intelligent battery management When a solar charge controller is not able to recharge the battery to its full capacity within one day, the result is often that the battery will continually be cycled between a ‘partially charged’ state and the ‘end of discharge’ state. This mode of operation (no regular full recharge) will destroy a lead-acid battery within weeks or months. The Battery Life algorithm will monitor the state of charge of the battery and, if needed, day by day slightly increase the load disconnect level (i.e. disconnect the load earlier) until the harvested solar energy is sufficient to recharge the battery to nearly the full 100%. From that point onwards the load disconnect level will be modulated so that a nearly 100% recharge is achieved about once every week.
The MPPT 100/30 doesn't have a load output.
Well, be that as it may....it has a setting for it and in my MPPT I have selected "Battery Life" in lieu of the other choices...but what exactly does this setting accomplish and HOW does it do it? Yes, it refers user to "Battery Life Chapter" in manual but that chapter does not exist; or at least I could not find it...
Also how does an MPPT "monitor SOC"? 712 does keep track of the SOC with a shunt, and honestly, not all that well. I have a BB 100Ah Li battery.
Since the 100/30 don't have a load output that setting does nothing.
If you still want to know what that setting does look in the manual of the smaller MPPT that have a load output.
Mppt works on battery voltage. You can configure this in the settings,
For solar, the 712 needs to be configured so the 100% is just below the absorption voltage, also tail current set lower. Then you get good readings.
35 People are following this question.
