Hi all,
I have just installed a ESS system of 3x quattro 48/8000 in 3 phase system. Firmware 487.
I have installed an ET340 energy meter just after the grid intake. I have a 6kw windmill connected on the AC-in1 side of the Quattros, parallel to the grid. It works fine and when we have wind to produce power, it charge up the battery, (22kWh).
My problem is all load are connecte to the AC-out1 on the quattros, but is only fed by the grid when the windmill are stopped, and battery are not used aad stays full. The picture showes the load without the windmill
I have a Cerbo GX to control the system.
Is there a way to use the battery first, in this ESS setup?
![img-20210930-wa0000.jpg](/storage/attachments/24266-img-20210930-wa0000.jpg)
