gregoryfierens avatar image
gregoryfierens asked
Read the ESS Battery Status Reason Code Numbers over Modbus : possible ?
Hello - I am trying to track the ESS Battery Status Reason Code Numbers
• #3: BMS disabled charging
• #4: BMS disabled discharge
I thought I could just read addresses 38 (ESS disable charge flag phase) and 39 (ESS disable feedback flag phase) through Modbus; but even with scan_interval = 10s I cannot see any change. Is there another way to track these ESS Battery Status Reason ?
ESS
leoo avatar image
leoo answered ·
I'm digging this up again as I just encountered the same problem trying to create a digital twin of my cerbo-gx. I could probably re-create the ESS-Reason codes based on the underlying rules with other values but that would not be ideal.
Are there any registers available that I can get the ESS-Reason codes from using modbus?
elvis avatar image
elvis answered ·
@Leoo @GregoryFierens
Is this what you need?
https://github.com/victronenergy/venus/wiki/dbus#ess-formerly-called-hub-4
Optimized mode with BatteryLife:
1: Value set by the GUI when BatteryLife is enabled. Hub4Control uses it to find the right BatteryLife state (values 2-7) based on system state
2: Self consumption
3: Self consumption, SoC exceeds 85%
4: Self consumption, SoC at 100%
5: SoC below BatteryLife dynamic SoC limit
6: SoC has been below SoC limit for more than 24 hours. Charging with battery with 5amps
7: Multi/Quattro is in sustain
8: Recharge, SOC dropped 5% or more below MinSOC.
Keep batteries charged mode:
9: 'Keep batteries charged' mode enabled
Optimized mode without BatteryLife:
10: Self consumption, SoC at or above minimum SoC
11: Self consumption, SoC is below minimum SoC
12: Recharge, SOC dropped 5% or more below minimum SoC
Or something like this?
https://www.victronenergy.com/media/pg/Energy_Storage_System/en/controlling-depth-of-discharge.html#UUID-898081fc-12c0-210f-e2d4-db3e3c8c28fb
1: SOC is low
2: BatteryLife is active
5: Slow Charge in progress (part of BatteryLife, see above)
6: User configured a charge limit of zero.
7: User configured a discharge limit of zero.
