lizirueti avatar image
lizirueti asked
Pv voltage to high smart solar mppt 100/20
I got 4 of such controller and have for each measured 70 V input (2 panels in series) max 10A.
manual said max 100 V . yellow and green leds are blinking, means to high voltage.
1. problem app did not fins any controler, maybe another smart phone works..
2. how on hell could i sort this problem out.....
1. first connect pv and try if controler is working than shut offf.
2. i connect my 48V opsz battery.
any clue?
MPPT SmartSolar
Alexandra avatar image
Alexandra answered ·
@lizirueti
It probably auto detected the voltage for the battery incorrectly as you connected pv first not the battery. Are you sure you have the 100/20 48V model?
You will need to prioritise the programming now to correct the issue. Use the victron connect bluetooth troubleshooting guide.
lizirueti answered ·
Dear Alexandra, many thanks for your reply.
i got 4 x
smart should support blootooth.
Voltage should 12/24/48 automatically or adjustable by app....
Have not heard or read about different
smart solar mppt 100/20 models
if i am wrong how can i verify mines?
How can i teach the controler to accept 70 V from my pv??
70 V should be accept with 12/24/48 V batteries
Alex was referring to the battery voltage. Maybe the MPPT is set to the wrong battery voltage.
All 100/20 working with 12/24/(36)/48V.
You have to use the VictronConnect app to check that and switch it to 48V if needed.
lizirueti avatar image lizirueti Matthias Lange - DE ♦ commented ·
Hallo Herr Lange Sie hatten mir schon mal geholfen. Ich habe jetzt eine umfangreichere Inbetriebnahme von 3 Multiplus II, 1 Cerbo GX und MPPT rd 450 / 200 vor mir. Würden Sie mich mit Anydesk, Teamviewer, Telefonisch supporten zum
Stundesatz x? Bei Interesse gerne anrufen +491713162566 oder mailen mehr1@gmx.net danke Gruß
