So … might be just dum luck (or very poor documentation from Wakespeed) … but I got DVCC working on the WS500 WITHOUT having the batteries on the same CAN network.
I can adjust the target volts in Victron / DVCC and the WS500 follows. If I break the victron/ws500 connection, WS500 falls back to it’s programming.
As my other charge sources ramp up, the current limit on the WS500 goes down (currently set at 200 A on Victron DVCC,
Here, I have Victron DVCC set at max 200 A. I have 6 Amps of solar coming in, so DVCC passed 194A as the max limit for the WS500
How did I set it up?
WS500 connected to Victron Cerbo GX (v1) via 250 kbps VE.CAN port (terminator on Cerbo and terminator on WS500).
WS500 Battery:
Generic / lithium / custom settings
WS500 System tab:
On the GX device DVCC is enabled:
On the GX Device under settings / connectivity:
VE.Can port: VE.CAN 250 kbit/s, NMEA 2000 out is off (I find NMEA taxes the Cerbo GX a lot, I use Signalk on a RPI5 to handle various data sources to/from N2k (Victron, ESP32 devices, etc…).
I also programmed white space … to unload the alternator at low and high RPM.
However, in order to also have full output while charging at anchor, I have a switch connected to the white wire. With 12V applied, it follows the white space. WIthout 12V applied, I get the full output (my Alternator tab is limited to 85 deg C and 90 pct field).
I really wish Wakespeed and Victron would document this feature set a little better…
BTW, My batteries are SOK 314 Ah, connected via Victron CAN protocol on the 500 kbps BMS-CAN port. They drive the DVCC volts, max charge current, etc…
In the winter when not using the boat much, I bring the DVCC max volts to 13.6V. This is a bit easier on the batteries and keeps me at 95-98 pct SOC (no issues with cell balancing, I have 2x 314 Ah in parallel).
One thing I still can’t get from Wakespeed is can I connect it to both Victron VE.CAN and my N2K network at the same time ? I have the WakeSpeed cable for this (with the NMEA2000 connector) but then I’m not sure if I need to remove the resistors from the WS500 and CerboGX, as they would essentially be connected as a Spur on the N2K Canbus network…
Notes:
- When making connectivity setup on the Victron / WS500 I rebooted both devices to avoid any issues (Victron first, while ws500 shutdown, then boot up WS500).
- When setting up batteries on the WS500, despite selecting Brand Generic and 2x 314 Ah, when I copy the config from the WS500 back to the app It shows up as Battleborn , model: Custom and 1x 630 Ah
- When changing settings on the System tab, scroll back up. Sometimes changing something at the bottom changes things up top (like disabling Current shunt on Alternator and enabling Current Shut at the Battery)…
- All my charge sources (MPPT, Inverter/Charger, alt regulator) have a fall back charge profile that is correct for my batteries / electrical system, in case the Victron Cerbo goes offline.
- I disconnected the NMEA 2000 cable from the WS500. It’s only connected to the CerboGX for now.
The Wakespeed Android app appears to have some bugs or UI elements that need further refinement.
