I have installed a Wakespeed 500Pro alternator regulator with Cerbo GX mk2 and smart Lithium batteries to operate in DVCC mode with the alternator info visible on the Cerbo. and am struggling to get it working fully. I have two scenarios as follows:
I can get the system to work nicely in DVCC mode if the 500Pro and batteries are both connected (& properly terminated) to the Cerbo at 500bps baud rate (500Pro LED flashes orange indicating slave mode and the charge current is controlled by the battery bank) BUT the 500Pro is not visible on the Cerbo device list or touch screen. I can monitor the alternator using the 500Pro app but not the Cerbo, which is not ideal but it works!
However, if I connect the 500Pro to the other Cerbo port and set its baud rate to 250bps (on 50-0Pro & Cerbo) the alternator is now visible on the Cerbo BUT the 500Pro doesn’t receive the battery data and goes into fault code #42 “Battery not detected via CAN”.
Is there something I need to set up in the Cerbo to ensure the data is exchanged between the two CANbus ports or am I missing something?
Any help gratefully received!
Regards,
Kevin
