I am installing a Xantrex C40 to use as a dump load controller for microhydro. I want to visualize the output from my microhydro onto the VRM that my Cerbo GX gives me. Will a smartshunt installed onto this new input source to my battery system work for this purpose? I already have a smartshunt installed for the larger PV system, so this one would be additional.
katefraser
(Kate)
1
lxonline
(LX)
2
If you are using it as a DC meter then yes.
You can then enable has dc system as well. It will appear as a tile
Related topics
| Topic | Replies | Views | Activity | |
| Smartshunt as DC current monitor in Cerbo GX (has DC system) | 13 | 1061 | 17 October 2024 | |
| Adding shunt to measure DC generator | 6 | 564 | 13 November 2024 | |
| Direct DC loads and shunt | 24 | 557 | 16 December 2025 | |
| Smart shunt as DC meter not Showing in VRM (wind turbine) | 11 | 357 | 21 December 2025 | |
| SmartShunt as DC-meter not showing values in VRM or in Panel | 2 | 163 | 19 May 2025 |
