My still unrealized project started in 2019 with 23 kWp PV and 60 kWh BES low voltage.
The house grow, the roof overhangs increased, and even the efficiency of PV increased.
At 33 kWp and an additional 10 kWp PV at the garage, I decided to change to high-voltage batteries.
But I always receive this great offers for 51.2 V 314 Ah batteries. I always asked the vendor, “Can this be used serial” and I always received the answer “Only parallel allowed”.
The next problem had been the availability of MPPT to connect many different PV fields. Only 120 € EXW China to connect 5 kWp PV. Many offers for 48V MPPT but absolut nothing to find for high-voltage batteries.
My high-voltage design was based on 2 Solis 20 kW hybrid inverters because each has 4 MPPT.
One is only connected to the grid; the second is only connected to the house.
I started last week with the big redesign back to low-voltage. First surprise: Only the high-voltage inverters from Solis are on the TOR-list in Austria.
Next surprise: DEYE 20 kW low-voltage inverter is on the TOR-list, but has only 350 A from battery to grid. When the batteries are at 42V, only 14.7 kW.
The high power is only for selling electricity at high spot market prices.
I assume 20 kW are only in a combination of PV and battery.
High spot market prices are usual when solar yield is very low.
Next surprise: 120 W standby. That is really unbearable.
So I changed the design to 3 Victron Multiplus 48/6K5.
AFAIK they can be switched off by software command to nearly nothing.
The 3 Victons are only for selling electricity and car charging.
The house will be connected to a cheap 4 kW 48 V inverter.
house tech room.pdf (47.5 KB)
All the PV with MPPT. One roof side has 30 × 670 W modules.
3 MPPT handles 4S2P, one 3S2P.
