After the update of from the app, I get some strange warning message, (See screenshot) when I using the VRM app.
On IOS. Also refresh is not working anymore. For the rest I think it’s working normal.
I’m the only one?
I get this too, same error message, doing nothing special, just loading the dashboard, using Android
Same here!
Ok than they will fix it soon or later. Have the troubles also on pc.
Lately, every time I enter the VRM dashboard, I get this.
No matter that I am coming from inside VRM environment, from another section / menu option, or I am coming for the first time in VRM webpage.
I am the sole user (admin) of my installation.
Things started today…
LE: BetaVRM is not showing this problem…
Nope, I have similar problems, including messages about insufficient permissions with code 1512
@alexpescaru I’m having the same message on my mac VRM running in safari so has to be Victrons end
Thanks for confirming.
Same on ~15 beta venus
I have just been on VRM without issue and it is reported as being fixed on the old community site.
https://community.victronenergy.com/questions/331573/warning-1512-when-opening-vrm-dashboard.html
Thank you!
I Pick this toppic up.
Since this morning I got this message also on my Desktop
I was just about to start a new topic and found this one opened at around the time that I first started experiencing the irritating pop-up stating “You don;t have sufficient rights to perform this action”.
It started at first on the recent update to the VRM iphone app and now it is occuring on the VRM web portal as well.
Is Victron aware of this and when will it be resolved?
Same problem described by the community with 1512 warning !
Hi All,
Thanks for the reports, the VRM team has found the issue and will deploy the fix shortly.
Edit - this fix is now live. Please report if you see it again.
Now all is back !
I had the same but am back now for the web url and VRM app
I’m going to close this now because it has been resolved in this case.
There is a chance it occurs again, but then create a new post rather than trying to bump this old one.
