As one can see the Widget data copy for some reason reports Battery temperature as -17.9C! I’ve no idea where this comes from as I’m in a subtropical area battery temp consistently around 25C, as reported by the real sensor. Everything else in the BESS is working as it should. This appears to be a VRM issue maybe?
The energy collection is very low as we have had very overcast rainy day yesterday and today.
Welcome.
I suspect that the battery temp is coming from the battery BMS.
Possibly under DVCC untick STS, and confirm batt temp.
I’ll look tomorrow, thanks for the suggestion.
As an aside, my Pylontech batteries have a firmware issue which gives the Victron equipment false readings but only at the cell level, the battery headline reading is correct.
