The temperature relayed by my Globallink 520 doesn’t get plotted in the VRM.
From memory this never worked.
The data points are more “sparse” than others, but are there.
I never cared much about temperature until switching to Lithium
Is there a way to get the charts or some visuals?
See both widgets, the standard one and my custom:
Buona sera Emilio ,good evening,
The Widgets must be activated under “advanced” you see on the top right of the page the symbols “search”,“downloads” and then “widgets” there you go to battery monitor and then activate the battery temperature sensor…Good luck
Hi Frank, thanks, the widgets are activated.
What I am saying it that I cannot see the chart line in the widget itself. See the first animation I posted. That is a screen recording from the battery widget on my VRM.
