VRM Solar total wrong
Yesterday I installed extra 3P75CT and removed half of my microinvertes behind ET340 and moved these behind 3P75CT.
ET340 is PV Roof and 3P75CT is PV Shed. 3P75CT has 1.08FW and my venus was 3.54
And now it seems that VRM total Solar is way to big (not possible with my panels).
Here is image of todays summary (Solar 90 kWh)
And here is summary of two energy meters and two solar chargers in advanced menu.
If you add these together you get 63,2kWh that is what it should be.
So can someone explain why vrm summary is showing wrong number? Around 26,8kWh extra what I did not generate today.
Looked for yesterday and the same thing (total solar 59,5kWh)
And in advanced menu total is 40,73kWh (it was more clouds and it is accurate)
So it seems that 3P75CT is calculating correctly but in VRM total it’s production is somehow taken account two times.
And one more thing, in advanced tab “System - PV Yield” is showing 12kw max production for today. But it vrm summary there was over 15kwh in one hour, that is impossible.
I also have one MQTT PV that is one phase microinverter measured via shelly plug, but that has only one 280W panel.
And here are my devices list, so no double PV devices. There must be something wrong in the system itself :frowning:
Physically restarted 3P75CT and upgraded venus to 3.55 so both are restarted today evening.
So lets see what are total PV generation summary tomorrow.
It seems that restarting both venus and 3P75CT helped because two next days summary and advanced menu solar kwh where the same.
But I would like to know why dashboard calculated to way solar in two days after installing 3P75CT :slight_smile:
