VRM data solar-to-direct-use not correct
In a new installation I have an issue with the data shown on the VRM.
The setup is a multiplus II GX 5000VA (L1 to AC-IN) with an ET340 (grid meter) and ET112 (PV on L1) on the same RS485 bus with changed modbus ID’s.
AC-OUT is not used.
The realtime data seems correct:
The battery is trying to keep the grid-setpoint at 10W.
During the day, the solar energy is supplying the house and/or charging the battery.
Yet I get this graph for solar production.
It’s strange to me that solar-to-direct-use is almost zero while I would expect a graph like this. (same day from another installation)
Here it’s clear that no energy is wasted.
Also, the consumption graph shows a lot of consumption from grid while in reality most of the consumption was supplied by solar power or battery.
To me it seems like a visualisation issue in the VRM.
Does anybody have any idea how to solve this?
Thanks
Hi All,
I have similar issues with the just installed Energy Meter VM-3P75CT. The MP2 is only delivering 1 Phase on AC Loads but VRM showing 3 Phases. Energy Meter is configured as Grid meter.
I think I have solved my issue.
See here: EM540 and ET112 - #14 by BramE
Do you have a 3-phase Multiplus setup?
No.
The graphs seem to be quite broken, my installation shows no direct use at all (though no MP2 there, just normal inverters):
