I have problem with the VRM 2day installation bar chart has changed and does not show hour intervals ??? The one day chart has not changed and does show hour interval, Can we roll back the upgrade ?? Thanks N1ck
From what I i can see, that is just labelling that changes.
It is a bit interesting if you change devices the scaling changes and then four hour labels appear. So it’s also probably something to do the screen you are viewing on.
But the bars for each hour are still there.
Hi Lx many thanks and just to clarify it is the same on both iPad & iPhone (if that makes a difference) but the “yesterday” and “2day” options now give different results and I need the hours reading on the “2 day” as was previously available. !! Many thanks Nick
Same here, the previous 2-day display with hourly intervals is way better
Hi Steven
Many thanks and glad to know I’m not the only one with the issue / requirement and let’s hope we can get it back to the hourly reporting as it’s a bit of a hassle having to use the “24 hour” report with a calculator !! Regards Nick
Hi Steven
It’s back … 2 day report returns to hourly many thanks Mr. Victron ![]()
