VM-3P75CT v1.09 Firmware Changelog?
Hi all,
are there any changelogs for the v1.09 firmware release of the VM-3P75CT?
I can’t find them …
with best regards,
Björn
Hi @bagel, you can find the changelogs of firmware releases on Victron Professional (you need an account but anyone can sign up).
Below is the v1.09 excerpt from the changelog.
Changes/features added:
  • Fix total power reporting for absolute and arithmetic registration.
  • Add keep-alive mechanism for VE.Can power snapshots to reduce the CPU load on GX devices for non-grid roles.
  • Add power factor reporting according to IEEE convention.
  • Add phase sequence reporting for 3-phase configuration. Requires VenusOS v3.60 or later.
  • Add phase rotation warning for 3-phase configuration.
  • Add averaging for most reported measurements.
  • Improve overall measurements accuracy.
  • Improve PLL locking mechanism.
  • Make Ethernet communication more robust.
  • Update bootloader for v1.06. Fixes reporting of incorrect application version on mDNS.
for some reason I can’t see this update in the device says 1.08 is the latest I’m also going running 3.64
Hi @Daza, version v1.09 is available on VRM and Victron Professional. It is not yet included in Victron Connect.
You can either update through VRM firmware update or downloading v1.09 on Victron Professional and adding it to Victron Connect and update the VM-3P75CT manually.
