Recently updated the VM-3P75CT
v1.09 – 12 August 2025
Changes/features added:
- Add power factor and phase sequence reporting. Visible in the GX device, VRM Portal, and the VictronConnect app.
- Reduce required GX Device CPU load when using meters for PV Inverter, AC-load, or other types of metering and connected using VE.Can wiring. The same improvement for connected using Ethernet wiring was already available per Venus OS v3.60, released before the summer of 2025.
- Add phase rotation warning for 3-phase configuration, visible in the VictronConnect App.
- Improve overall measurements accuracy.
- Fix total power reporting for absolute and arithmetic registration. The most used type of registration, vector, was not affected by the issue.
- Make Ethernet communication more robust.
In my case the analyser is in the mains connection situated and i want to be able to see what the Cos.Phi (or maybe presenting as P.F. . ) is.
question is how to present the value(s) (in 4 kwadranten? )
