First time user of Victron, configured many EPEVER Charge Controllers. The application is to provide (solar) power to a remote PTZ camera and it currently works fine using an EPEVER Charge Controller. I elected to clone another but this time using Victron, since it was cheaper and smaller. I was very impressed with the build quality of the Victron charge controller.
My application uses NMC leaf cells (4s) for the BATTERY and setting absorption (16.80V) and float (16.40V) on the Victron was very straightforward and works fine.
Then I came to set the LVD, low voltage dropout. I went to ‘Load Output’ menu in settings and selected ‘User Def Algorithm 1’ and set ‘Load Switch High Voltage Level’ to 14.20V and ‘Load Switch Low Voltage Level’ to 14.00V. So it disconnects when the BATTERY drops to 14.00V and reconnects when the BATTERY reaches 14.20V. That works fine.
I was testing my setup on the bench and found that with no load on the ‘Load’ connector, it all worked great. I measured the voltage at the ‘Load’ connector using a DMM. The problems started when I connected the real application to the “Load’ connector. Nothing worked, not even ‘Always On’, the Load output remained off, which was also reported in the APP.
Digging into the problem showed that connecting an LED load worked fine. I tried two light strips, 700mA and 2.0A and both behaved flawlessly. I broke out the scope to see what was happening, screenshots included. We get good switching with the light strips connected. With the application, which takes about 300-400mA, it tries to bring up the load, but then gives up. The load for the application is a PTZ camera (Hikvision) with POE injector and a CPE210 (TP Link) wireless client driven by another POE injector. The 24V and 48V required by the CPE210 and CAMERA are generated using DC-DC converters powered from the LEAF (NMC) cells. The DC-DC converters appear to be the cause of the ‘Load’ failing to switch. I can provide a schematic and a BOM if required.
Any ideas why this is happening.
Regards,
BRIAN
Screenshots:
#1 PTZ application connected
#2: With the 700mA lightbar connected
#3: With 2.0A Lightbar connected.
