Victron Multi RS 6000 Net Code password?
Hi everyone! I am currectly testing a new setup with 3x Victron Multi RS 6000, but when I try to setup the grid code, I need a password that I cannot find.
I already have a Multiplus system up and running and I know that you can only set the grid code once on the multiplusses, but it seems that for the Multi RS Solar, you need a password for the first time too.
I have upgraded the firmware to version 1.2 on the Multi RS, but still I cant seem to setup a grid code.
I want to test ESS (and after that DESS).
Thanks in advance for your help.
@vaursechs
This is something you are to talk to your dealer about. If you don’t know who your dealer is use the support page.
{As per the changelog for v1.19}
Summary
In that screenshot it specifically says it is allowed to select a grid code ONCE. But I just powered up my Multi RS Solar for the first time and connected it to Victron Connect (VE-Can → Cerbo GX). However I am not even able to select grid code for the first time. I bought the units at Nkon.com, I guess they are the dealer?
Possibly. If they aren’t then they will have a dealer that supplies them. In the meantime i have made my own enquiries.
Hi @vaursechs . This is a bug in the current VictronConnect release.
Fix is already announced by Victron.
v6.20beta2
Changes
Multi RS:
Enable setting the grid code for the first time without requiring a password
I could find the password with the right search terms via Google as quick fix. Of course, your Victron dealer is the recommended and official source.
