Victron Lynx BMS
Hi there, i have 2 x multiplus 5k invertors being feed from a bank(20) of Pylontech 48v batterties. These batteries are being charged with 2 x Victron MPPT units. System working fine, but i wish to introduce a feed from a 48v 3kw wind turbine..
Should i take say 5 of my batteries, create a seperate stack and link via a Lynx BMS unit and feed these with wind turbine via the Hybrid controller from the wind turbine.. i estimate my normal/average 48v supply will be less than 1kw.. the wind turbine hybrid controller can be set to cut off at day 90% Battery SOC.
Your thoughts.
The Lynx BMS only works with Victron batteries. What were you hoping to achieve with it.
