Help
just got a 5KW easysolar 2-GX system.
all working fine on the AC and solar side but how do I setup so the AC stops when the Batteries are fully charged.
I use 3x LiFE4833P batteries.
Help would be appreciated.
Thank you.
Can you explain a bit more what you want the system to do?
when the system is on AC input it will stay on AC-grid supply.
I like to have the system switch to Solar when there is lots of sun.
all other functions working very well.
How can I switch the automatic transfer from AC to Solar/DC supply?
Can not find Info how to program this.
thanks Marc
You wil need to program the ess assistant, but you will need a grid meter for that to work properly
