I am evaluating a Victron EasySolar-II GX 48/5000/70-50 MPPT 250/100 GX for a domestic battery-first PV installation in NE Scotland (yes, we do actually get sunlight!)
The intended architecture is:
PV array → internal MPPT → 48V LiFePO4 battery
Grid supply → AC-in / charger (or alternative charger if necessary) → battery
Battery → inverter → dedicated consumer unit supplying selected house circuits
The inverter output would supply a dedicated consumer unit and would not be connected to circuits supplied directly from the grid.
The intended operating philosophy is:
- PV is the primary energy source.
- Battery is the primary energy buffer.
- Loads are normally supplied by the inverter.
- Grid power is only used as a backup battery charging source when battery SOC falls below a defined threshold and PV not available.
- No export functionality is required.
- No ESS, dynamic tariffs, grid balancing or energy trading functions are required.
I am trying to determine whether the EasySolar-II GX can be configured to operate as follows:
- PV charging always active.
- Mains AC-in normally ignored
- Mains AC-in enabled only below a configurable SOC or battery voltage threshold.
- mains AC-in used solely for battery charging.
- AC-out continuously supplied by the inverter.
- No normal Mains AC passthrough operation.
Specific questions:
- Can AC-in be used purely as a backup charging source while AC-out remains permanently inverter supplied?
- Does enabling AC-in necessarily involve AC passthrough or transfer-switch operation?
- Is there any permanent electrical connection between AC-in neutral and AC-out neutral?
- How does the internal neutral-earth relay behave in this operating mode?
- Is there a documented configuration example similar to the above?
I am interested in the technical capabilities and wiring topology of the EasySolar-II GX rather than ESS or export-oriented installations.
I’ve looked at the manuals, however a few questions have remained.
