Venus OS on Raspberry 3
Hello
A few weeks ago, I bought a Victron charge controller for the first time, and I would now like to be able to access its data via the internet.
I’ve heard that I can install Venus OS on an old Raspberry Pi and then connect the charge controller to the Pi using a VE.Direct cable.
The Pi boots normally, but then does nothing. I connected a monitor via HDMI, and the blue Victron logo is displayed. It’s not possible to enter anything using the keyboard. A connection via the IP address is blocked.
How can I get the Pi up and running?
I’m not particularly familiar with the Raspberry Pi and Linux, but I do have Windows and Linux Mint computers available.
Rene
Try entering venus.local in your browser while connected to the same network and have a little look around
And a warm welcome to the blue world.
Hi DirkW
Thanks, I had already tried that too — unsuccessfully.
I can ping the IP without any problems, but in the browser I can’t access it using either the IP or venus.local.
Just to be absolutely clear, I don’t have a Cerbo, only the 100/30 charge controller and a SmartShunt. Both are connected via VE.Direct USB adapters.
If I’ve understood everything correctly, the Pi should now effectively replace the Cerbo.
Do you have the right version of Venus for your RasPi? There are differences…
Have you also flashed the image onto a suitable SD card?
There are some good videos with instructions on how to prepare the image.
I can’t check that right now because there’s currently no card adapter available, but it should be fine.
Flashed the OS onto the card with Balena Etcher; it was successful every time.
Today I wanted to upgrade the ancient 2.92 large to 3.75 large on my Raspi 3 (connected via Ethernet). Through the web GUI (remote console), it showed that it was downloading it up to 100%, but it never actually installed it. I thought, „Okay, it must be because of the ancient version“, so I flashed the SD card. It boots, ping works, but the web UI doesn’t. I connected a TV via HDMI: no GUI, just a command prompt. So I installed the standard „non-large“ version: lo and behold, it works. Updating to the large version via the GUI then shows the same phenomenon: it downloads up to 100%, but nothing actually gets updated. Is this a known problem?
Moved to modifications section, the home of the raspberry pi.
