Venus OS 3.50 - GUI 2.0 Solar Yield Details UI improvements suggestion - shows red for cleared alarms
Heyo and greetings for 3.50 update!
Found the interesting and a bit annoying behavior. When you click on solar yield on the overview page you see all solar chargers. In my case, it’s 3xMultiRS + Smart MPPT 150/35. When I click on any RS charger, I see the Alarms & Errors section that highlights in RED that “4 found” (see the video). But when I entered inside I saw that all alarms were OK (and there were no alarms so far that day, as well as the previous one). I would change red to a generic color (like white or black) and make it red only when the actual alarm is triggered.
Yes, the same with an MPPT RS 450/200:
And in the alarm menu the states “ok” and no “real” alarm.
Can you see some kind of an alarm history if you connect to the device with VictronConnect?
No alarms today, as well as yesterday
Same is happening on multiple sites with the MPPT RS here.
No Alarms
Good feedback, I agree. Can this please be changed @mpvader?
Yes - noted; will be looked into
Same issue on mine as well :pray:t5:
I have the same problem so i guess a bug that will be fixed soon. I have one other problem, I am off grid but have a generator that is manually started when needed, the Multi RS solar is conneted to cerbo GX and has generator set as AC input 1 and AC input 2 set as not available as there is only one AC input.
I continuously get AC grid loss alarms on VRM page and on the cerbo GX after a reset or if Multi RS is turned off and back on after a storm. I have even set as not available for AC input 1 and still get the alarm.
Matthew
It IS fixed. See Changelog V51~2.
And for new Issues, read this thread first :slight_smile:
@mpvader @guystewart thank you for fix! much better :slight_smile:
