am still leaning :
DSE : I have generator having DSE Controller hgm6120n can not be pick on system.
AC: I use the AC breaker to switch off the AC then the gen starts. I am trying to use the Venus CX relays to switch on and off AC But I am failing to make the relay work
VENUS: I did all settings. I once pressed the reboot and the gen started only once
First, search the forum as many topics may already have answers or makes for a good starting point e.g.
In the absence of a lot more detail, I suspect you want to look at using an AC contactor that you can control with the Venus by wiring it to the relay on the Venus.
If it did it once but will not work now have you damaged the relay by overloading it especially if it had a load with an initial higher power surge. There have been many instances of failed relays with contacts welded closed or melted open due to overload.
