under generator settings Conditions low voltage it is NOT possible to do anything with anything other than 12v batteries
Tested on both UI’s
Same in 3.52
Is your system a 12v system?
You probably need to explain a bit more.
It does NOT matter what system you have (mine is 48V)you can NOT set it to be over 12.3V
It does matter for troubleshooting purposes. As John mentioned its is fine on other systems.
So to help or potentially find a bug, more information about your system is needed.
V3.52 has been officially released. So topic moved to diy. Or it can go to Q&A
Apologies did not think it would matter as it won’t go beyond the 12.3v
Hi JohnC
Found out you Have to Set STOP value at the Bottom of the settings list screen BEFORE you can set the START value at the TOP of the settings list.
Which makes perfect sense to ?
Trap for Logical thinkers
anyways
All fixed now
Thanks
