VE.Direct or VE.Can MPPTs
Hi All,
I am about to expand my solar and add an east/west array which will require another MPPT or even two. My current one is an RS type connected via VE.Can but the smaller MPPT controllers (what I will need) tend to be VE.Direct and I would like to know if I connect both types how will it all work together. Will the VRM see them separately and equally ? Will the VE.Direct version have any benefits or drawbacks compared to the VE.Can model ?
Thanks in advance,
Functionality should be the same - VE.can however allows you to daisy-chain many MPPTs and not need individual wires run to the cerbo. Depending on the count of devices required, that may become an advantage.
Ok, that helps me make my choice of MPPT controllers.
Thanks,
