VE.Bus Smart Dongle Temperature in VRM Portal
I have a campervan system which I’ve recently added a Pi based Venus. All devices are connected to a VE.Smart network. I just setup VRM portal connectivity for the first time and trying to surface Battery Temperature so I can monitor it from the portal and set alarms. Temperature for the VE.Smart Network is provided by a VE.Bus Dongle connected to the MultiPlus. Temp works fine in the local network, and is accurate, but I can’t get it to display in the portal. I’ve tried every temp parameter I can find for every device. Is this not possible?
I also tried configuring Temp based alarms and the only parameter that displayed data is this one, but I’m pretty certain my battery is not sitting at absolute zero.
SmartSolar Charger MPPT 100/50
SmartShunt IP65 500A/50mV
MultiPlus Compact 12/2000/80-50 120V (via VE.Bus Dongle)
Orion XS 12/12-50A
Generic Venus Device (Pi v3.70~60)
*All on latest firmware.
Any help is appreciated. Thanks,
