V3.60~59 CAN1 down
Last night I uploaded a new beta version. And in the morning the MPPTs were not visible. Obviously the communication via CAN1 was lost. After restart - OK. I wonder if the error will happen again… So far I have had no problems with communication on VE.Can1.
cerbo mk2, 4x MPPT on VE.Can.
Are you using guiv1 or v2
Guiv2
Hi, noted, thabk you for the report. Is it ok if we login to your system @KRUP85 ?
We’d like to have a look at the logs.
For that to be possible you need to enable Settings → General → Remote support.
Yes, no problem. Remote support enabled.
Hi again, thanks for allowing access. Conclusion is that we still have more work to do wrt that VE.Can 2 fix now in v3.60~59.
No problem. I’m happy to help.
So far the error has not reappeared.
Hi again @KRUP85 could you install v3.60~65, as per here:
It includes various improvements for CAN stability, as part of the kernel update. And so far testing seems good; but the issue you had is quite rare - hence more testing is better!
I agree, it was weird. Plus it hasn’t happened again since.
I just updated to 3.60 ~66. We’ll see.
