V3.60~17 generator warmup missing
I have loaded 3.60~17 in my cerbo gx and all appears to work except for the generator warm up/cool down setting does not appear under gen stop/start/settings.I have tried in old and new UI.but the setting is not available.
Hi @Rondo,
We can’t reproduce the issue on our test systems. Note that you’ll need a vebus system or MultiRS with warm-up and cool-down capabilities for the menu to show up.
Do you have a vebus system or multiRS system? And what firmware version is that running?
Regards,
Rein.
firmware in quattro is v497 i will update later today thanks.
Hi both :+1:.
to add:
Two requirements:
  • VE.Bus fw needs to be 502 or newer
  • A component inside the GX, called the MK3, needs to be updates as well. A popup or menu item will show in case there is an update for it.
More info here:
