Have you loaded any mods? Guimod, setup helper etc?
You can check in settings → general → modifications.
If you do, please use the disable option in that mods menu, use the reapply firmware option (it preserves settings) and restart.
Almost all the issues have so far been down to incompatible mods.
No, I haven’t made installed any mods. I’d give a screenshot, but I have nothing to show. Maybe that screen doesn’t show in V1 GUI? Or since I don’t have any installed.
Here’s my config:
Cerbo GX
Multiplus2 24v 3kva
MPPT 100/50
Custom DIY Battery with JK BMS, DVCC over Ve.can
MQTT enabled to HomeAssistant.
qml: Cannot load electrical quantity, mqtt/settings/0/Settings/Gui/ElectricalPowerIndicator has unsupported value: undefined default to watts
qml: Cannot load temperature unit, mqtt/settings/0/Settings/System/Units/Temperature has unsupported value: undefined default to celsius
qml: Cannot load volume unit, mqtt/settings/0/Settings/System/VolumeUnit has unsupported value: undefined default to m3
If you click on the settings cog bottom right on the new UI, does it not work at all? It looked like the GUI was opening, just no values were showing.
incidentally, only time I saw that was when the network quality was too poor for the messaging to work, so I would also double check anything that might cause a slow connection.
v1 and new GUI have different needs.
You can connect to the built-in AP of the GX to verify if everything is ok.
Is this a wired or wireless connection?
